Kevin @ Nutech has been great helping me get my AD2USB talking to my alarm panel, and that works fine now. Next step is connecting to vera.
I have not seen a getting started guid with step by step instructions (ie install plugin , configure these parameters, etc, on these screens in UI7, etc, etc).
If you have successfully installed this device in UI7, and can please point me in the right direction, I would appreciate any help you can give!
I can confirm the AD2USB on the laptop can control and see the alarm panel. The serial port on Vera shas been enabled by VERA tech support, I no longer get a cannot communicate message, both the partition and the Alarm panel plugin now have no errors.
I enter my PIN code, press store, and get a success message. I cannot get any further, and need some help. Not sure what to enter on the CHEAT SHEET section. Does the system, when correctly configured, create a device on its own automatically?
