Does anyone know/can confirm if you can see the gas usage in the app? In the SQ remote app this is not possible, it only support kWh which I find a disadvantage.
Is this a plugin for some system that appears in the Vera dashboard?
Yes, this one:
Then it should work just fine. I haven’t tried it specifically but I don’t see why it wouldn’t work.
Thx, will let you know
It works!!!
