Hi. New to Vera.
My alarm system cannot be directly integrated w Vera but I did request the installer drop an NO trigger wire that is closed when the alarm system is activated. I would like to use this output to have Vera change to Away state when I activate the alarm.
Is there a zwave appliance that can detect closed circuits or electrical input I could use for this purpose? Any other thoughts?
TIA
Mine is a very basic implementation, and still it isn’t what I’d like it to be, but the basic task of putting Vera into “Away” mode when the alarm panel is armed, and then to arm some Vera’s sensors to get notified is something happens in my house while I’m away, is easily accomplished…
Hope this helps in setting you on the right path…
Cheers
Joe
