I know this is possible using LUA code, but I don’t know the code
I found if (luup.is_night()) then
return false
else
return true
This code is perfect for something I only want to happen during the daytime… However in my case I want this scene to activate ONLY at night based on a trigger (alarm panel armed). Help?
I actually use both already, however I couldn’t figure out how to tie them into the scene.
I should be more specific on what I am trying to achieve:
When it is night
AND
TRIGGER - The Honeywell alarm panel changes from “Armed” to “Disarmed” state
Activate some lighting
It was the “And” part that I was having difficulty with. PLEG would seem to be the anwer, however I couldn’t figure out how to use it for this scenario. So I plan to use the use the Luup code to inhibit the scene during the day, which bypasses the “AND” portion of the logic.
PLEG Tigger Inputs: Night When Day or Night Indicates Night Disarmed When The Honeywell alarm panel changes from “Armed” to “Disarmed” state.
PLEG Conditions: AutoOn Night && (Night; Disarmed)
PLEG Actions: AutoOn Run your scene … or just turn on the lights directly.
[hr]
The above condition will only fire if the alarm is disarmed AFTER it’s night.
I would like to execute a similar scenario, turning on lights when the alarm is active only at night, but im lost in the condition tab, i will appreciate your help
Tigers
Alarm Active When the DSC indicates an active alarm
[quote=“petequintanilla, post:10, topic:175208”]I would like to execute a similar scenario, turning on lights when the alarm is active only at night, but im lost in the condition tab, i will appreciate your help
Tigers
