I want to control my Fan with a KaKu ACM-LV10.
This module has a 0 - 10 Volt output, which I can input in the control voltage of the fan.
I want to make an automation that controls the fan according to a humidity sensor.
More humidity should result in a higher voltage…
I have a RFXtrx and this works fine with other KaKu devices.
Who can help me?
Regards,
Rob
Update:
I have paired the remote with the ACM-LV10, and the device is now visible in Vera.
If I press the On buton, the voltage increases, and I can control it more or less.
The goal is however to sent the “dim value” directly to the module. So I can use an automation process to set the “dim value” to 3 in case of a low humidity, and to 8 in a high humidity. And of course some steps in between…
Rob
