I deleted /usr/lib/lighttpd
Could anyone give me /usr/lib/lighttpd files?
Thanks!
I also accidentally deleted some files in my Veralite. Not sure if copying files from another vera will work. I have to follow these steps to reflash the firmware:
http://wiki.micasaverde.com/index.php/Firmware_Flash_VeraLite
I am not home, but I believe the files are actually on a readonly partition and symbolically linked into the /usr/lib area.
Just take a look at other files in that area.
Thanks for your replies.
Don Phillips, AFAIK It’s not possible to compile lighttpd at VERA as there’s no configure for sure.
Also I tried to open in many ways .squashfs and .bin files - no way.
Hellovn, As for Firmware_Flash_VeraLite there’s a mark @YOU NEED TO FOLLOW THIS TUTORIAL ONLY IF YOUR VERA UNIT IS NOT BOOTING ANYMORE@ and I do not want to reupgrade it then and load backup.
RichardTSchaefer, I thought also about this, but /mios/usr/lib/ contains no lighttpd.
I found the copy of all files in /rom/
So files from lighttpd are there /rom/usr/lib/lighttpd
