Is it ONLY possible through a specific URL (hosted by vera) or If I properly configure my firewall and have dynamic dns – can I access Vera’s web server that way? Thanks for your input
For outside the home, either through the MiOS server infra or via a [Private] VPN tunnel that you setup on your network.
Some of the more advanced users have done the latter, since it typically requires more technical setup (along with an extra step before using any of the Control Points)
Port forwarding, or firewall rules, that put any part of Vera directly to the Internet is not safe.
I appreciate your input. Could you please throw some insight on how Vera is communicating to MIOS server? Is it establishing a VPN from Vera device to MIOS or is it through HTTPS? Thanks again for your help.
Vera creates ssh tunnels to the mios servers. This setups port forwarding to allow the servers access to vera.
- Garrett
Thanks Garret. So based on your inputs this is what I understand:
- Vera doesn’t have a built in web server.
- Vera establishes SSH tunnels to mios servers and mios web server communicates to the specific Vera.
- It should be possible to login to Vera locally through telnet or SSH client?
Wouldn’t it be much easier if the same MIOS web server app is installed on the Vera itself? Thanks again.
Sure it does. It’s called lighttpd and it’s what you point your browser at when you are on the same LAN as Vera.
2. Vera establishes SSH tunnels to mios servers and mios web server communicates to the specific Vera. 3. It should be possible to login to Vera locally through telnet or SSH client?
Yep. (But not telnet.)
Wouldn't it be much easier if the same MIOS web server app is installed on the Vera itself?
Not for most people. To communicate directly with your Vera you would need:
- To set up port forwarding on your gateway, assuming that you are behind NAT like most users.
- To get and install an SSL certificate so that you can communicate over HTTPS and prevent eavesdropping on your password. Self-signed certificates don’t count.
- To have static DNS or set up dynamic DNS, and hope that it doesn’t mess with your SSL certificate. Probably that means buying a domain.
That’s about the minimum you would need to ensure security and foil packet-sniffers. Most consumers don’t even comprehend the items in that list, much less could configure it all.
Now think about how mios.com’s remote access server works:
- There’s a reverse SSH tunnel, which is really just glorified port forwarding.
- There’s an SSL certificate that end users’ browsers trust.
- There’s a domain with static DNS.
See the similarities?
I have left out things like firewalling, user management and redundant servers, because you might be able to skimp on those for a home deployment. But mios.com has them.
If you follow this recipe you can roll your own mios.com. Personally I went the VPN route instead, as it was easier to set up and doesn’t expose lighttpd to the Big Bad Internet.
If you set up your router with ssh access you can use an ssh client on the machine you want to connect to vera to create an ssh tunnel to vera’s webserver at the time you want to logon.
It is pretty simple if you are good with ssh tunneling, which can be very confusing. But that drops the list of requirements to a dynamic dns service, an ssh client (like the free ‘putty’ for Windows or the built in ones for OS X / Linux), and of course a router which supports ssh.
I understand also that it might mean replacing the built in ssh on some routers (I think tunneling might be disabled on it on the default ssh server for openwrt for instance).
I’m not sure this is necessarily simpler than @futzle VPN solution.
If you follow this recipe you can roll your own mios.com. Personally I went the VPN route instead, as it was easier to set up and doesn’t expose lighttpd to the Big Bad Internet.[/quote]
@futzle: Thank you very much. Your detailed description is pretty awesome and really helped me clear up few questions I had.
[quote=“radarengineer, post:7, topic:169090”]If you set up your router with ssh access you can use an ssh client on the machine you want to connect to vera to create an ssh tunnel to vera’s webserver at the time you want to logon.
I’m not sure this is necessarily simpler than @futzle VPN solution.[/quote]
@radarengineer: So based on futzles’s and your input (copied from futzle’s post) - I probably will go this route:
Also I recently remember creating a PERL script that uses NET::SSH::Perl that was able to login and submit ssh requests and get the response back - so I’m thinking I could always use something like that to automate few things if needed.
Once again thanks for futzle’s input and yours. I greatly appreciate it.
Oh, and one little extra thing. Password-protect yourself by requiring some kind of login to the gateway. HTTPS is all well and good, but it doesn’t prevent someone stumbling onto your Vera’s control panel while port scanning. If you use mios.com as a model, you keep the username/password pairs on the gateway, and when a correct one is entered, the gateway generates a session ID which goes into a cookie. All future requests with a good cookie get forwarded to the SSH tunnel.
Great Forum
Thanks again futzle. So I went ahead and ordered MCV :-). With others sharing and helping, gives me lot of excitement to get this setup.
So far I ordered the following to start with…
Mi Casa Verde Vera 2 Home Controller
Trane TZEMT400BB3 Thermostat
Monster MCC AVL 200 Central and Lighting Control Revolution 200 (Black)
(I got the following free with it as amazon had a special offer to get 3 products free with the remote)
1x Monster Cable ML IWS1000S
2x Monster Cable ML IWD600S 600-Watt In-Wall Dimming System
@mysticjay, the forum participation is one of the reasons I ordered a Vera back in February when I was first deciding to mess with home automation. I have been very happy with mine and hope you will be too.
I just got around to installing my Trane thermostat a few weeks ago. I use a swamp cooler in the summer and will probably get around to hooking it up to the thermostat with relays this weekend. It seems like a really nice thermostat even without the z-wave functionality.
