Access via ssh
I’m trying to look at log files. I try to ssh in using 10.0.1.2 which I found under Account/Veras. The wiki says I’ll be prompted for a username and password. I only get a password prompt when typing ‘ssh 10.0.1.2’ so I tried root@10.0.1.2. Either way, the password I use to login to Mios doesn’t work. The wiki refers to a WiFi password or HomeID printed on the bottom of the Vera unit. I don’t have any such ID on my VeraLite. I have a MAC address, a S/N and an FCC ID. Any help?
Mike
Vera Lite does not have a password printed on the label, but you can retrieve it through other means. See if this thread helps? Another option is mentioned on the wiki page.
Thanks! I went with the wiki option and it worked.
