Hi
I recall this being done on the earlier Veras, but after searching the forum, I cannot seem to find any reference to it now?
Is there some code you can use to retrieve the status of the LEDs on the top of the Vera Plus ?
Hi
This was the post with the VeraLite solution in EventWatcher http://forum.micasaverde.com/index.php/topic,16984.msg177617.html#msg177617
I’ve never bothered to try on and Edge or a Plus. In fact, I removed the code from EventWatcher in the latest version.
Arrr thanks for the mention in the EventWatch code
-- System info blog -- -- thanks to @parkerc for the idea, and @futzle for the solution, to "watching the LEDs" -- see: http://forum.micasaverde.com/index.php/topic,25217.msg177527.html#msg177527 -- # ls /sys/devices/platform/leds-gpio/leds/veralite:*/brightness -- blue:power/brightness, orange:zwave/brightness, red:error/brightness, yellow:lan/brightness --
And this looks to be the code segments
local function getLED (x)
local path = "/sys/devices/platform/leds-gpio/leds/veralite:%s/brightness"
local value = tonumber (getSystemFile (path:format (x)))
return value or 0
[code]local power = getLED “blue:power” – LED status lights
local zwave = getLED “orange:zwave”
local lan = getLED “yellow:lan” – it’s actually green
local error = getLED “red:error”
info.VeraLiteLEDS = {val = error + 2*(lan + 2*(zwave + 2*power)) / 255, class = ‘system’} – encode into one variable
[/code]
[code] local LED = systemInfo.VeraLiteLEDS.val
set (“AppMemoryUsed”, AppMemoryUsed)
set (“MemAvail”, mem)
set (“MemFree”, free)
set (“CpuLoad05”, cpu)
set (“VeraLiteLEDS”, LED)
set (“IconSet”, LED % 8) – only use lower three bits of status (ie. ignore powerlight)
collectgarbage ()
[/code]
Now I have a temperature JSON to help graph things on Status Board, ( thanks to your huge help ) I’m curious to explore the idea of a simple Vera Status (web) widget that shows the status of my Veras.
Looking on my Edge, I only see a /sys/devices/platform/ directory with nothing apparently led-related in there.
I did not check, but may be the suggestion from @guessed as per [url=http://forum.micasaverde.com/index.php/topic,25217.msg177528.html#msg177528]http://forum.micasaverde.com/index.php/topic,25217.msg177528.html#msg177528[/url] to look at /usr/bin/set_leds.sh still holds ?
[quote=“guessed, post:3, topic:181278”]Take a look at /usr/bin/set_leds.sh to see how the LEDs are managed on each hardware model. Looks like they’ve taken a fairly standard route and mounted them under a virtual filesystem.
I imagine you can read the values back from there to get their current status.[/quote]
Great call! This points to /sys/class/leds/ which contains, on my Edge:
na301:green:lan na301:green:power na301:green:service na301:green:zwave
Therein lies the answer, I think.
Nice !!
Ok - I’m not near my VeraPlus to check - but I’m going to assume much of the getLED function is still the same other than the change of file location etc.
And rather than encode each one into a single variable (as I think like You/ @akbooer has done) - I’m going to need each variable to be seperate so I can some how present them in a table/list form with some sort of colour statue icon - based in the colour reported.
One questions - what is the full address / file name of the one used on the Vera/VeraLight - assume UI5 - as I’ll look into a way of doing both - as I have Ui5 & UI7
I don’t understand what is meant by this - I was expecting a file extension at the end ?
/sys/devices/platform/leds-gpio/leds/veralite:blue:power/brightness
/sys/devices/platform/leds-gpio/leds/veralite:orange:zwave/brightness
/sys/devices/platform/leds-gpio/leds/veralite:red:error/brightness
/sys/devices/platform/leds-gpio/leds/veralite:yellow:lan/brightness
Interestingly, on the VeraLite under UI5, you also have:
# ls /sys/class/leds
veralite:blue:power veralite:orange:zwave veralite:red:error veralite:yellow:lan
which are directories which contain ‘virtual’ files including, for example:
# cat /sys/class/leds/veralite\:blue\:power/brightness
255
…so, in fact, this little code snippet should work on any machine:
local lfs = require "lfs"
local leds = {}
local leaf = "/brightness"
local root = "/sys/class/leds/"
local mcv = "(%w+):(%w+):(%w+)$"
for branch in lfs.dir (root) do
local m,c,v = branch: match (mcv)
if v then
local l = {}
for x in io.lines (root..branch..leaf) do l[#l+1] = x end
leds[#leds+1] = {machine = m, colour = c, functionality = v, value = l[1]}
print (pretty(leds))
on a VeraLite this produces:
colour = "red",
functionality = "error",
machine = "veralite",
value = "0"
colour = "orange",
functionality = "zwave",
value = "255"
colour = "yellow",
functionality = "lan",
value = "255"
colour = "blue",
functionality = "power",
value = "255"
…and on an Edge:
colour = "green",
machine = "na301",
value = "255"
colour = "green",
machine = "na301",
value = "255"
colour = "green",
machine = "na301",
value = "255"
colour = "green",
functionality = "service",
machine = "na301",
value = "255"
This is close to what you need.
Thanks @akbooer
To start with I’ve designed a basic HTML table widget/panel to be used with Status Board, and I’ll now try and work out how to make it reflect the statuses of the controller.
