I only have one trigger which is a PLEG routine. In that routine, I also included a HomeWave push notification so I know if the device was triggered with the PLEG. The phantom is not a result of the PLEG. There are no other triggers. Since I turned off support access, no events occurred yet.
Scheduled to go on two hours before sunrise. Last night the EtherRain 8 started around 21:45.
The USB has my AD2USB in it so verbose logging was off on the unit. I turned it on with “Archive to the server” so perhaps I can get the MCV folks to help out.
Look at your logs. If need be go back several minutes prior to the sprinkler turn on. There is most likely a scene running that is causing this action.
I realize that you stated that you don’t have a scene for this, but sometimes one might accidentally click a device within a scene that is completely unrelated and not even realize it.
Not that this has ever happened to me, of course. But, I’ve “heard” of this repeatedly happening to “a friend of mine”.
In my case I am using a wireless bridge to connect the EtherRain to my home network. Periodically the wireless connection between the bridge and my main wireless router would drop out. When this occurred Vera indicated an On state for the EtherRain.
