I currently have a EZMotion 3in1 but it will not arm. I can press the ARM button all day, but it doesn’t change. And the single Scene i have “Sunset Prep” is suppose to ARM the sensor, does not arm it either.
The Light and Temp do change regularly.
Capabilities 83,156,0,4,32,1,R,B,RS,|48,49:5,112,114,128,132:2,133,134,155,
Version 6,3,52,3,6
Manufacturer Ryherd Ventures
VERA
version: 1.5.622
INSTALLED ARE
Mios Update and All the Pro Logic Plugins.
what are you expecting it to do when it is armed ?
The arm/bypass status is only used by the Vera Software.
The motion sensor tells Vera ever time it sees a motion.
The Vera Software then uses the Arm/Bypass status to decide if any scenes (or PLEG/PLTS input trigger) need to be fired.
The user has the ability to specify a trigger based on motion … or armed and motion.
Right Now, I am just trying to get it to ARM. I am pressing the ARM button, but nothing happens. However I do have a couple Scenes that I would like to use with this device…
I want it to act like a Motion Senor on the front porch that turns on the lights when someone approaches.
I added an image that should explain how I set it up.
When you click arm … the Arm button should stay selected. When you click Bypass … the Bypass button should stay selected. That’s all it is supposed to do.
Is it not doing that ? It looks like it did when you armed and bypassed them in your Prep scenes.
Are you expecting it to do something else ? If so what ?
[quote=“RichardTSchaefer, post:4, topic:177247”]When you click arm … the Arm button should stay selected. When you click Bypass … the Bypass button should stay selected. That’s all it is supposed to do.
Is it not doing that ?[/quote]
That is correct, It is NOT doing that… it never arms.
