I am looking to update several of the Z-Wave Dimmer Switches that I currently have (Evolve) that seem to continuously fail. I am hoping for a few opinions on replacements.
1.) I need 3 main switches (1 controls, 1 light) the other two control cans and need 2 accessory switches each.
2.) I’d like something that does Instant Status, so I can use if for scene triggering.
3.) Something that you would consider “reliable” not needing to be replaced every so often.
What defines whether Vera can have instant status for a switch or not? I’m curious about the newer Zwave plus switches coming out from GE/Jasco. They support command classes 133 and 89, the association and association group info. They seem to use group 1 which presumably the controller will see. Will this be enough for Vera? Do you know specifically what Vera is looking for to support instant status?
