ALTUI seems to give a more user friendly UI to do this. In ‘table devices’ view I was able to delete devices much more quickly.
[quote=“Peren, post:15, topic:197752”][quote=“Heber, post:10, topic:197752”]Hi,
My RFXtrx master device disappeared from my list of devices after uploading these files. The actual devices (lamps etc) that were set up previously are still working but I cannot access the RFXtrx device to add or make changes.
Any ideias? Thanks![/quote]
Same here. Anyone knoww how to get it back???[/quote]
For me I had to upload the plugin files. It turns out I was on beta3. Uploaded the files under trunk and then the ones included here and now I got the main device back and it works as expected.
Hope it helps!
Hi, I have uploaded all of the files, I am still unable to add a device in the rfxcom, any ideas?
This sucks!
Restored Vera frombackup and I got my vera 433 devices back.
Tried agin with new instrucstions when vera has’nt corrected it.
Same again, broken Vera…
[quote=“Peren, post:24, topic:197752”]This sucks!
Same again, broken Vera…[/quote]
Glad I’m not trusting Verawith my alarmed migrated to Vera Secure. The stability of vera and no response from support makes me look for something else if they don’t shape up. I was so happy in the beginning for the wide support of accessory and so on, do not want to go from Vera but…
Thank You Tinman, finally got it working again after I uploaded your 2 files to my VeraEdge plus. but After replacing the files, I had to turn the vera completely off and restarted it again, after that everything working fine and I can now create new device for my RFXcom
Merci Tinman. It work fine after loading all files in zip, then restart Vera, then delete (wait little bit), the refresh list.
I had the same issues with adding and deleting devices, so uploaded these two files, restarted the Vera, and then, my RFXtrx device has disappeared!?!?
WHat happened?
Edit: Never mind I updated all files to version 51, and got another issue/question, in that thread.
Are you able to upload these files again? Can’t seem to access them from the new vera community forms
You can download the latest version here: Plugin Update V1.87 - USB RFXtrx Transceiver - Ezlo Community
