Hi @curiousB we already noted down all your previous requests. Let us proceed on them one by one. We started to add polling for power capability. Then we will do in this order:
- modify template parameters via device settings
- stop polling after the device is not reachable for some time. Later I want to restart polling / or check manually if the device is reachable
- use door/window and motion sensors capability in sensor device types.
- test HTTP requests while creating the template and see the response on the page directly.
- set MQTT topics instead of HTTP URIs to send device commands, get data via mqtt messages ( this can be done in parallel if we can)
after those we will start working on multiple device capability.
