Your message wasn’t delivered to support@getvera.com because the address couldn’t be found, or is unable to receive mail.
The response was:
550 5.1.1 The email account that you tried to reach does not exist. Please try double-checking the recipient’s email address for typos or unnecessary spaces. Learn more at Fix bounced or rejected emails - Gmail Help p3sor577298plq.34 - gsmtp
I just checked ticket 249392 and it has been replied to this morning by Oscar. Please check your email’s inbox and spam folders. Apologies for the inconvenience.
I am having many problems of devices (mainly Fibaro door/window sensor FGW-002) becoming offline/online frequently. It seems that it could be one of the problems fixed by this beta version, is it?
But, at the same time I see that many other users are still having problems with this beta version, then my question is: If I upgraded to this new 7.32 beta version, using the backup procedures of course, in the case I would have new problems, would I be able to return to my current 7.31 version using the restore procedure?
My main current problem is that the sensor doesn’t report a door open/closed situation, I did an unpair in my VERA Edge controller, it did it, but when I tried to pair back it again, it gave the message “Successfully Exchanged Security Keys”, but later on it gave “Device failed ti configure” message and it stayed at “waiting for wakeup” and, even if I tried it to wakeup clicking its button, it didn’t.
It doesn’t matter if the sensor is virtual, real, or just a stub. But it turns out, it’s pilot error on my part. It looks like when I installed a previous Beta, I either opted for “factory reset” or the “mode settings” under My Modes got reset to default, like this:
and in that default, sensors were not honoring their ModeSetting state variable on the devices. I personally think it’s odd to have a separate setting for “default” or “custom” when each device has its own ModeSetting that is itself default or custom, but that’s my bias, not a bug for you. Sorry for the error.
I updated my Vera Secure a couple of days ago. Today when I got home, the Vera is dead. No led lights, no nothing. I switched the power adapter, and no change. It’s dead. Period. It was two years old.
Can I try anything? CPR? Or is it time to move on?
Best regards,
/Fanan
I’m sorry to hear that. There were some posts about reviving a bricked Vera Plus or Edge but they needed a bin file from the support group and you had to be able to connect to the unit to load it.
If it’s not a power supply issue then I would suggest that you reach out to support to see if there is a secret handshake that can be used to revive the Vera Secure for a factory reset.
Hi crew,
Is there a plan or date for beta 5, or the final release?
I now have a spare box, so thinking of upgrading the offline unit, but only want to do it once
Octo
Hi @jesus.ramos
I’ve tried that and everything else. It’s clinically dead. I contacted the support, and they said that the warrenty period is over, so I should buy a new controller.
@Fanan , as you seem to be in sweden you have a three year complaint period (reklamationsrätt) according to the consumer purchase act (konsumentköplagen), the complaint should be directed at the reseller.
I have had the battery for my vera secure replaced twice by my reseller (loh electronics), the last time was after about three years.
