I am having trouble getting my Aeon 4in1 to control my Current Innovations CI800 stat.
Both units are visible and working under the device tab in Veralte UI5. The sensor has been firmware upgraded already.
I am new to scenes though, and wish to let the Humidity portion of the sensor to be a trigger? to ask the thermostat to run on cooling setting to reduce the humidity levels in home.
I have read the portion of the vera manual dealing with scenes, I think I call a scene a name ask the stat to set up cool and auto fan . Then I create a trigger from aeon humidity sensor? to tell stat to start above my set point for humidity?
I do not live where the zwave system is installed so wish to adjust the humidity levels remotely.
I have started to read up on luup but believe this will not be foe me as I’m no programmer.
If this is not possible is there a Humidity unit on the market that will work for my app.
Any advice would be appreciated
