Hi all. I’ve done a ton of research, (e.g. [url=http://forum.micasaverde.com/index.php?topic=9160.0]http://forum.micasaverde.com/index.php?topic=9160.0[/url]. I’ve learned a lot, which is always worthwhile. So many intelligent people in this community.
I believe that all of the multi switches in my house (3 and 4 ways) have the main feed going direct to the light and then out to the switches, with dead-ends. I’ve drawn this conclusion after finding only 2 travelers and 1 common in the three way switches. I am trying to wire the lowest end, GE 3-way from Lowes. I think I have one option to make this work, but it has been a few months since I gave up last. Not all of the boxes have other neutral wires that I can tap to power the aux switch. Here is my thoughts:
Pull the wires out of the ceiling at the light and identify the two travelers going to the three way and main switch
Convert one of the travelers from each switch into the zwave traveler that goes between the switches, wire nutted at the light.
Convert the other traveler going to the aux switch into neutral. (mark appropriately)
@aux, identify the new traveler and neutral, test, mark, connect and ground.
@main, tap other neutral, wire load, line and ground.
@Oti - The main switch is a shared box with others that have a neutral. The 3-way stands alone w/o a neutral.
@bulldog - I like that option. This also would keep the existing switches. Which diagram for this 3-way situation? 3-way has only 3 wires, two travelers and common, +ground.
I highly recommend that you do not assume anything. Get a voltmeter, and verify which lines go where, at each outlet. Might save you from considerable problems down the road.
yup, use caution and “Know” which wires are the line, not conclude by looking. Use the voltage meter.
You should try to wire like “3-Way with Live Wire” This means you need to ‘wrap’ your traveller through the 3ways as diagramed. The wall switches will cause a signal back to the Aeon (a pulse). The Aeon detects that pulse and switches state.
Same neutral / circuit as the light is on? This is essential.
If there is a neutral in the main box, and there is a line, you could possibly power the Z-Wave switches and light from that. But you have then moved the light from one circuit to another.
If there is a neutral in the main box, and there is a line, you could possibly power the Z-Wave switches and light from that. But you have then moved the light from one circuit to another.[/quote]
Plus, it is a 3-way switch setup, so that adds more complexity. I would not recommend changing the switch to a new circuit, you may inadvertently create a crossover and a safety hazard.
I highly recommend that you do not assume anything. Get a voltmeter, and verify which lines go where, at each outlet. Might save you from considerable problems down the road.[/quote]
yes, that is representing in both “Identify” and “Test” in my steps.
Everything in the box is on the same breaker… but does that mean same circuit? No?
Another option. One of the lights is in the garage. Given the location of the 3-way, I will never use it… have not used it once. Is there a way to cap it off an convert the main switch to a standard switch? Sounds easy.
yup, just close the circuit by connecting the wires. You will then need to replace your three way in the other box with a single pole.
Then you have a phantom box and an unused traveller, which electricians and homeowners usually despise. Just put a note in the box after you cover it, you should not leave the old switch there.
You should probably keep the integrity of the circuit and wire it as it is with the existing 3-ways. But if you want to use your new three way kit, and not wait for the AEON, have at it.
There have been previous discussions here on this topic. When I tried it, my circuit breaker kept tripping. It turned out the problem was my lighting circuit was on on Arc Fault Circuit Interrupter (AFCI). Many others have reported success using a neutral from a different circuit. In the load center, all of the neutrals land on a common bus (unless AFCI or GFCI protected).
If so, and you’ve got that separate neutral available to your GE master switch (45609), I believe it is possible to use these switches with your circuitry. I find the GE wiring diagrams to be very confusing. Attachment 2 presents it in an easier to understand fashion. As mentioned above, verify all of your wiring. Don’t trust that the wire colors are correct. Especially in your scenario, they probably are not. Assuming all of the above, the circuit depicted in Attachment 3 may work for you.
If the wiring is as displayed in the above linked image, the GE/Jasco 45609(ZW4001) or it’s 3-way derivative cannot be used. Additional wires are required.
There have been previous discussions here on this topic. When I tried it, my circuit breaker kept tripping. It turned out the problem was my lighting circuit was on on Arc Fault Circuit Interrupter (AFCI). Many others have reported success using a neutral from a different circuit. In the load center, all of the neutrals land on a common bus (unless AFCI or GFCI protected).[/quote]
What is working, and what is safe / allowed, are different things. I would have taken the breaker tripping (due to an imbalance) as a sign that the problem is with using a neutral from a different circuit.
OK. Presumably there is a line (hot) in there as well? You could power the GE main from that, then use the 3-wire going to the light as load/neutral/traveler, disconnect the light from the original feed and cap it, and wire the aux accordingly (per your original plan / and cap any unused wire).
(I’m assuming the posted diagram does not reflect your situation / your light is ‘in the middle’, as you mentioned identifying and connecting the travelers to either switch at the light.)
Point taken. It was previously allowed, but using a common neutral is restricted under NEC 2011. There are some exceptions. See 200.4, 215.4. It is allowed in feeder circuits, but not branch circuits. The potential risk is from adding too many circuits to one neutral and overloading that wire. As far as my previous issue, I am pretty sure it was due to the AFCI. It did what it was designed to do.
(I’m assuming the posted diagram does not reflect your situation / your light is ‘in the middle’, as you mentioned identifying and connecting the travelers to either switch at the light.)[/quote]
Exactly what I was thinking. Attached is another diagram to reflect that. If it is a light ‘in the middle’, that would obviously require different wiring.
If so, and you’ve got that separate neutral available to your GE master switch (45609), I believe it is possible to use these switches with your circuitry. I find the GE wiring diagrams to be very confusing. Attachment 2 presents it in an easier to understand fashion. As mentioned above, verify all of your wiring. Don’t trust that the wire colors are correct. Especially in your scenario, they probably are not. Assuming all of the above, the circuit depicted in Attachment 3 may work for you.[/quote]
YES - This is how it is wired.
[quote=“Z-Waver, post:15, topic:179321”]If the wiring is as displayed in the above linked image, the GE/Jasco 45609(ZW4001) or it’s 3-way derivative cannot be used. Additional wires are required.
If the wiring is the same as the previously linked diagram, an Aeon Labs Micro In-Wall Appliance Switch can be used. As depicted in the attached diagram.[/quote]
I think this is the best option. I will put in the order and try this weekend. Stay tuned for an update.
