Looking for a Z-Wave 3-Way Switch that works on the 4-pin CFL recess light. I read somewhere here that the GE one doesn’t work on LED/CFL.
Anyone got a recommendation on a good quality one?
I have one of the switch connecting to an LED recess light as well I am interesting in replacing with DIMMING feature?
In general: you’d want to use bulbs that claim to be dimmable; and dimmers with a neutral yield better results than those without (as those without are typically only meant for true incandescent loads).
There should be some prior threads on what folks have found to be compatible (but it may come down to the specific bulbs you’re using, how exactly the combination behaves).
