Does anyone know how to get this 2GIG Takeover Module (Take) to connect to VeraSecure.
Johnny
Johnny
Hello there,
VeraSecure does not have any wired zones this device can attach to. Compatible 2GIG devices can be used directly with Vera without this module.
2GIG devices compatible with VeraSecure are :
2GIG 4-Button Key Ring Remote 2GIG-KEY3-433
2GIG Panic Button Remote 2GIG-PANIC3-433
2GIG Flood and Temperature Sensor 2GIG-FT1-345
2GIG Smoke Detector Sensor 2GIG-SDS1-345
2GIG Smoke and Heat Detector 2GIG-SMKT4-433
2GIG Motion Detector 2GIG-PIR4-433
2GIG Glass Break Detector 2GIG-GB3-433
2GIG Thin Door/Window Sensor 2GIG-DW14-433
2GIG Wireless Carbon Monoxide Alarm(2GIG-CO3-345)
2GIG Thin Door/Window Contact(2GIG-DW10-345)
2GIG Recessed Door Contact2GIG-DW20R-345)
2GIG Bypass Door Window Contact (2GIG-DW40-345)
2GIG Glass Break Detector (2GIG-GB1-345)
2GIG 4-Button Key Ring Remote (2GIG-KEY2-345)
2GIG Panic Button Remote (2GIG-PANIC1-345)
2GIG Passive Infrared Motion Detector (2GIG-PIR1-345)
2GIG Wireless Smoke/Heat Alarm (2GIG-SMKT3-345)
2GIG Tilt Sensor (2GIG-TILT1-345)
2GIG Wireless KeyPad 2GIG-PAD3-433
2GIG Wireless KeyPad 2GIG‐PAD1‐345
2GIG Wireless Doorbell 2GIG-DBELL1-345
I would second the support for the Takeover module, this would allow conversions of existing alarm systems to VeraSecure and avoid having to add wireless battery powered modules all over a pre-wired house. Is this coming soon? Couldn’t this device just show up as 8 motion sensors?
[quote=“Sorin M., post:2, topic:198202”]Hello there,
VeraSecure does not have any wired zones this device can attach to. Compatible 2GIG devices can be used directly with Vera without this module.[/quote]
Sorin, this works the opposite of what you think. The VeraSecure would make a wireless connection to the Takeover and it acts as a bridge & power supply for wired sensors.
People use this to migrate wired sensors from ADT or whatever onto a new 2GIG wireless control panel. The user connects hard wired sensors to the Takeover’s 8 zones and then you enroll the Takeover as as 8 RF sensors on a 2gig panel.
Ideally, VeraSecure would support it, allowing people to migrate their existing wired sensors onto the Secure.
I understand,
Our integration team would love to have a look at this if you log a ticket with our support team and make reference to this device.
Thanks guys,
Sounds like you two need to open support tickets.
I know it’s been a while, but has any progress been made with this takeover module?
