I have an issue in my house where the air does not circulate unless the AC is running, or if I manually set the fan to ON.
I am about to pick up a CT101 from Lowes (Once I find a lowes $10 coupon online I am looking) which is equivalent to the CT100.
I wanted to experiment with scheduling the Fan from Auto to On for 15 minutes every hour to circulate the air, in theory this should work since if the AC is running, it changes nothing but if the AC is not running, it will just circulate the air for 15 minutes.
Has anybody tried this?
