Hi amg0
Oh, and welcome back!
I like AltUI more every day, but I’m not able to get the second Vera to show. Using Google Chrome Version 45.0.2454.85 m with (2) Vera 3’s both running UI7 v 1.7.619 and AltUI V 0.68.655.
I just removed and then did a new install of AltUI from the Install Apps tab, then did the auto update to 655. Added the IP address for the second Vera, and clicked Open Window. The home screen comes up, but when I click Devices, it brings up a page of empty lines, and takes around 30 seconds before the devices show. Then I only see the primary controller devices, but no devices or scenes for the secondary Vera Not sure what I’m doing wrong, but hope you can tell me.
I’ve attached a piece of console log, and screen shots. 25 shows the settings screen in UI7 27 and 28 is the before and after the 30 second wait for the devices to show.
As always, I appreciate any help you can offer, and please let me know if there is something else you need.
Navigated to http://10.84.8.111/port_3480/data_request?id=lr_ALTUI_Handler&command=home
DayTime_0.png:1 GET http://10.84.8.111/cmh/skins/default/img/devices/device_states/DayTime_0.png 404 (Not Found)
devices.png:1 GET http://10.84.8.111/cmh/skins/default/icons/devices.png 404 (Not Found)
intro.png:1 GET http://10.84.8.111/cmh/skins/default/icons/intro.png 404 (Not Found)
J_ALTUI_uimgr.js:3960 Uncaught TypeError: Cannot read property 'altuiid' of undefined(anonymous function) @ J_ALTUI_uimgr.js:3960m.extend.grep @ jquery.js:483_deviceDrawWireFrame @ J_ALTUI_uimgr.js:3959_deviceDrawControlPanel @ J_ALTUI_uimgr.js:4050htmlid.pageControlPanel @ J_ALTUI_uimgr.js:5488(anonymous function) @ J_ALTUI_uimgr.js:5890m.event.dispatch @ jquery.js:4670m.event.add.r.handle @ jquery.js:4338
