hey there,
i have trouble getting 2 LED Stripe Modules to work on a V3 (black label) bridge.
is there any way i can hardcode the channel in the vera plugin or somethings ?
i also have the development plugins installed if that helps.
currently the V3 Bridge controls 1 RGB LED Lamp 1 B/W Lamp Set (3 lamps on the same channel)
an 1 LED Stripe
technically iam able to add another RGB channel to it, but the plugin always merge them with the first LED-Stripe controller.
any idea’s ?
also how do i un-pair the controller without a remote ?
5 times on does not really work for some reason.
