2.4GHz Wifi
For months I have been using my Vera Plus hub as a 2.4GHz access point dedicated to channel 6 today Vera has decided it only has 5G. This was set up dedicated to devices which require only channel 6 on 2.4 does anybody know how to either switch 2.4GHz back on or better yet use 2.4GHz only?
Things like this should not just randomly happen? Ive not even upgraded Firmware.
Hello AlphaHustle,
We have contacted you via email for further investigation. Please check your inbox.
Thank you!
