Is this not working?. Trying to set up new Vera, can’t get there. This is not a good sign for the last two hours. Can’t connect to server message.
Did you go to http://micasaverde.com/vera2 to set up a Vera2? The IP address you are specifying is an IP address on your local network.
Hello. Yes it says can’t find the server.It worked once and asked to up grade firmware, after that it won’t connect . Tech support non existent apparently. Except here.
It’s actually this address: http://micasaverde.com/vera2
JOD.
JOD that addy worked,it said scanning and returned this "ERROR
Cannot connect to the MiOS server."
I’m getting the same message.
“ERROR
Service not available at this moment, please try again later”
JOD.
Thanks, Will try later on.
