A short note to let you know that I was able to load the 10 Channel sketch, so now begins my adventure into a new experience, I will keep you posted.
Dom[/quote]
Hi
Can you guide me through how you did this? I also got it included as a dimmer, but when I try to upload the 10 channel code the vera wont detect it anymore. Did you restart anything?
I also have a question regardin future changes to the code (add or remove objects). Do you need to disconnect the z-uno from the z-wave network and include it again when you do changes or how does it work actually?
Dom[/quote]
Hi
Thank you!!
Stian[/quote]
Hi Stian,
You have to do exclusion+inclusion each time you change channel settings (number of channels, type, var sizes etc).
If you only change internal Arduino code then you don’t have to.
I already have 2 successful Z-Uno projects in my network. One collects temperature from 4 sensors and CO2 sensor. The other one is used for read out of electricity and gas meter (using pulses to detect consumption).
