1-Wire Microlan
I’m using EDS OW-SERVER-ENET2: [url=http://www.embeddeddatasystems.com/OW-SERVER-1-Wire-to-Ethernet-Server-Revision-2_p_152.html]http://www.embeddeddatasystems.com/OW-SERVER-1-Wire-to-Ethernet-Server-Revision-2_p_152.html[/url]
and the Plugin: [url=http://forum.micasaverde.com/index.php/topic,8381.0.html]http://forum.micasaverde.com/index.php/topic,8381.0.html[/url]
Starting to put together ideas of making my own environmental modules instead of buying these: [url=http://www.embeddeddatasystems.com/OW-ENV-TH–Temperature-Humidity-Sensor_p_168.html]http://www.embeddeddatasystems.com/OW-ENV-TH--Temperature-Humidity-Sensor_p_168.html[/url]
How about:
  • Temperature/Humidity sensor: DHT21 ($5.00 on eBay) [or SHT11 or SHT25]
  • 23mm x 12mm breadboard ($2.00 on eBay)
  • Small project box ($2.00 on eBay)
Does anyone have any experience with the DHT21 (or SHT11) humidity sensor with the EDS?
Are there better alternatives for humidity in combination with a DS18B20?
What do 1-Wire folks use for homebrew environmental monitoring?
The DS18B20 are good temperature sensors, but unfortunately there are no one-wire compatible humidity sensors available. The DHT21 is not one-wire compatible.
I don’t think there are a lot of options for humidity - I’ve seen some code for a pic that can emulate one-wire devices, so you might be able to get something like that working, but when I looked a year or so back the code wasn’t very complete.
For temperature, use the DS18B20. For humidity, I suspect you’re stuck with the commercial options (which while they aren’t especially cheap, they are no more expensive than Z-wave, and they are a lot better!). Or maybe someone will pop up with some other option…
Chris
Thanks Chris - you’ve saved me some grief. I did some searching to see what the OW-ENV-TH used for parts, but came up empty. I wonder if the EDS device has some on-board processing to convert a digital humidity sensor into Maxim 1-Wire compatibility… I presume then that the SHTxx sensors are also not Maxim compatible?
For temperature, use the DS18B20. For humidity, I suspect you're stuck with the commercial options (which while they aren't especially cheap, they are no more expensive than Z-wave, and they are a lot better!).
True enough, they’re not more expensive than Z-Wave, but I was hoping to be able to DIY something a lot cheaper and roll out a bunch of them! :slight_smile:
Or maybe someone will pop up with some other option...
I hope so!
Thanks again,
Dave
