A simple question , but not sure if a scene allows this.
A have a thermostate, for example I want it at 21 degrees C at 7:30 and 15 degrees at 23:00.
For the moment I have set up 2 scenes for that ,a schedule @ 7:30 for 21 degrees and a schedule for 15 degrees at 23:00 , works well , no issues.
When I am not at home ( for work I am always several days away) i need to cancel these scenes. that means 2 scenes to untick the scene.
Can I somehow use 1 scene , I only see a delay I can use, but for a specific time I don’t see how I can set a new temperature.
Options I can try:
-1 scene: start at 7:30 (21 degrees) and than a delay for 15 and a half hours ( set at 15 degrees)
-something with a virtual switch
-Luup code
-PLEG?? but pffff, so difficult , I cannot get the logic in my head :-\
Add actions to the above two Conditions.
(Sames as specifying commands to run in a Scene, but here we have two conditions, so the equivalent of two scenese)
If this PLEG is only used for this purpose … Bypass the PLEG when you are gone.
If you already have a Virtual Switch to indicate that you are home … then add it as a PLEG input: HOME Virtual Switch Indicates I am home
Then change the conditions to: SetTempMorning HOME AND TempAt730 SetTempEvening HOME AND TempAt2300
I was so afraid PLEG is the only sensible solution
I have PLEG installed and still struggeling with my gate opener ( threat somewhere here as well)… Good idea to use the virtual switch , I can use this as well for my gate issue …
With this thread I got my gate ( see the other thread) working . If this PLEG or the heating system works I will now in the morning … will it be freezing in my living room , or a nice temperature?
