So I had a couple of virtual thermostats that were working well.
You could set the temp on the virtual thermostat, read it with Luup code, and switch the heat on.
Now with the latest update, the temp setting and heat modes don’t seem to work.
That is, you set the temp in the webUI, but the luup the change is not set. For example, I set the temp to 70, and the value reflects the following:
“urn:upnp-org:serviceId:TemperatureSetpoint1_Heat”,“CurrentSetpoint” value = “50”
Anyone else seeing this?
Jim
