1.037.00 Bugs
We’ve identified some errors with 370. Sorry, it was a major upgrade that changed a lot of things for the new UI. We fixed most of these issues today. I removed the announcement from the forum and we’ll try to fix these issues and release a new version on Tuesday.
Regarding WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!..
That’s normal, actually. Just remove: /Users/Eriksen/.ssh/known_hosts
When Vera does a factory reset or upgrade without preserving settings, Vera will create a new host key. Some ssh clients, like Putty, just give you a notice and continue. But, ssh from the Linux console gives you a warning that the host key is different than it used to be. It’s to prevent you from accidentally ssh’ing to a box that’s faking another IP and trying to scam your password. You can just remove the known_hosts file, or just the entry for Vera’s IP.
[quote=“325xi, post:14, topic:164197”]Cannot remove scene with event. tried to remove scene first, or event first, save, refresh browser - noting happens, scene with event is still there. Tried to disable event in the scene - change isn’t saved.
Submitted report 231[/quote]
UPDATE: next day save worked. The same thing was with my “Retrying to save” problem - it’s gone next day.
I’m getting a feeling that Vera doesn’t like when Save or Remove occurs the same day the scene/event was created…
[quote=“325xi, post:6, topic:164197”][quote=“wseverino, post:4, topic:164197”]Dashboard doesn’t match the devices screen:
examples…The devices screen shows the outlet in my sons room confirgured properly. When looking at the dashboard its shows the icon as a red C, not configured.[/quote]
Same here.[/quote]
+1
[quote=“wseverino, post:3, topic:164197”]Location button from main screen does not work in firefox.
Scene button does not show the options to set-up scenes in firefox.[/quote]
Same here in firefox, and in IE.
I get the same retrying to save error when changing a scene…
[quote=“wseverino, post:15, topic:164197”]Interesting thing about scenes. I modified a scene and I get the following:
Saving local data …
Retrying to save …
Retrying to save …
Retrying to save …
Retrying to save …
Retrying to save …
Retrying to save …
Error saving data.
Submitting bug in Mantis…0000329[/quote]
+1
I have the same issue. I’ve seen this on two seperate vera units.
I just released version 404. This should fix these issues. Let me know right away if it doesn’t.
