I tried .985 and while using the Schlage lock there is a new box that give you a choice between forever code or between 2 dates choice. When I tried between 2 dates it kept disappearing and I had to reselect between 2 dates to keep entering the time. It also still shows 2009 as a choice which is annoying.
The other problem is when I tried entering a forever code after the between 2 dates code it would make it between the same 2 dates. I tried it over and over and same result.
The 3rd problem which was always there from the start of the lock firmware but is way worse in this version is that when I would click in the box to enter the code for the lock the cursor would disappear before I could type in a number. It would do this for about a minute over and over until it would stay on the box just long enough to enter the code and hit set. Most of the time I would only get one number in and it would go blank.
I don’t understand why the box had to be added to have a choice between a permanent code and between 2 days in the first place because it worked fine before in .979
