I’m trying to configure the motion sensor in my bedroom to turn the light on and keep the light on while it detects motion.
And then I would like the light to turn off within 30 seconds after I leave the bedroom…
I can only get the light to turn off after two minutes and no sooner. Is there a limitation in the sensor that will keep the lights on for a minimum of two minutes?
click “custom zwave settings” under the ZIR in the zwave devices menu, then if u scroll all the way to the bottom of the page it will let you put in a variable # and a setting.
my guess is it is going to be a 1 byte dec setting that can be set 1-255 just like the HSM100
dont forget to “configure node right now” after you set the variable, make sure to manually wake up your battery powered sensor before the configure too or it will fail
