As some of you have seen, 1.0.6 was approved by Apple this week. Apparently some users have been experiencing issues connecting remotely for some reasons, unfortunately I cannot reproduce this issue on my systems nor can you contact people who put reviews on the AppStore (thank you Apple).
If you are experiencing issues connecting remotely with 1.0.6, could you email iVera@thinkiwi.com so we can investigate and provide a fix as soon as possible. Thanks in advance.
Vera #1. Total of 3 devices. No issues loading.
Vera #2. Total of 13 devices. No issues loading.
Vera #3. Total of 145 devices. downloading data => downloading status and then returns a blank screen
I looked at your problem and found that the request made to MCV's remote server to get all the information about your Vera doesn't return any data. Even when using a browser with the same URL, it didn't work.
Those are APIs defined by MCV to communicate with a Vera gateway. If those don’t behave as expected, then remote access controller applications will not work.
AFAIK, the MiOS SmartPhone plugin uses the Luup Lua Extensions to enumerate scenes and devices and [tt]luup.register_handler[/tt] to add itself to your local Vera. That might be quite different from what iVera is doing …
I agree, and …
was trying to make a point that data was being returned by MCV’s server.
the request made to MCV’s remote server to get all the information about your Vera doesn’t return any data. Even when using a browser with the same URL, it didn’t work.
Since (iVera) is added as a user to my system he could prove to himself that my system is online and functional.
But this is not limited to being a remote issue, iVera does not work locally either.
It appears the way in which the data is being requested is too aggressive (for lack of a better term)
I’d have to agree with @JOD that something is going on with larger networks. I don’t know what the magic threshold number is (if there is one), but it definitely works better with a smaller number of nodes.
Typically, when I start iVera I get the ‘Vera server is busy’ count, a connection error etc. Subsequently things may appear to load fine, but then after swiping down the list of lights for example, it goes ‘busy’ again, at least once.
Local and remote. No difference with 1.0.6. I have had 2 Vera hang-ups so far; they definitely appear related to Vera-iVera interaction.
Haven’t been able to pin it down more; sometimes it just works fine.
What is 100% reproducible:
Start iVera without a LAN connection → ‘Vera server is busy’ 1 2 3 4 5 → ‘Connection error’ → do something else (e.g. click Lights) → crash
JOD, I wasn’t aware the mios smartphone plugin was using luup lua extensions to gather its data but so far, each time I’ve tried connecting to your system via cp.mios.com, direct URL or other remote access points (haven’t tried mios smartphone) … I get a “loading data in progress” message from UI4 and it never loads for me, the other never get the URL request back and end up timing out.
oTi@, can you email me at iVera-bug@thinkiwi.com so I can check your server as well. With 1.0.6, when Vera sends a new user_dataversion timestamp, iVera will reload the whole setup in the foreground whereas with 1.2.0, the entire update has been moved in the background so you shouldn’t get the ‘server busy’. However, if the problem comes from the fact that http requests to Vera or MCV’s remote servers are not being answered as expected when networks are too large, then this won’t solve the issue and needs to be talked to MCV about to understand why Vera is not returning the expected data.
@iVera,
Currently I’m not able to connect through cp.mios.com either…hmmm the Smartphone app is still able to connect though.
Remember we had a similar issue back with rev.1.0.2 (Sept 2010) that’s when you increased the time out period I believe…
JOD.
Those are fighting words.
Yes I mind. Aint no way I’m deleting any device!! ;D
Could we accomplish the same thing by changing the XML the Weather device uses? Or deleting the XML?
Either way, I cant do anything until later, later this evening.
I too after updating to the 1.06 seem to have hit and miss connectivity which I did not experience with earlier version(s). What I’m experiencing is that IVera attempts to connect, it connects but then freezes nothing works I end up exiting the app and retrying, have been able to recreate. I’m using my ITouch via WiFi connections. Mike
I am setting up a beta version so people who are experiencing issues can test out some changes prior to sending to Apple (since I can’t reproduce the connection problem in house). Thanks.
Running our vera2 since a week now, controlled locally through UI4, remotely via cp.mios.com (using ssl) and on 2 iphones (3g on iOS 3.12 and 4 running iOS 4.01).
Obviously i tried the free version first and upgraded to the full version a few days later.
Works with my light switches, scenes, Generic IP camera and weather app (only sensors supported).
Works fine, only after changing the layout in iVera, i sometimes get a " server busy" lock up in the app.
Shutting down the app and restarting solves this problem.
Quite pleased so far. Waiting for reply from thinkiwi on my request mail regarding support of the weather plugin
Vera2 1.1.1245, Z-wave 3.20, Duewi light switch, Ycam IP camera, looking for upgrades on windowblind controllers and thermostat
[quote=“iVera, post:15, topic:168238”]Michael, could you email me at iVera-bug@thinkiwi.com?
I am setting up a beta version so people who are experiencing issues can test out some changes prior to sending to Apple (since I can’t reproduce the connection problem in house). Thanks.[/quote]
