hello there, does anyone have the same issue ?
if the temperature goes above 35 Degrees, the value do jump to 50 flat.
any way to prevent this from happening ?
use zxt-120 Version 1.5
I had a 1.5, it will only happen when ambient temperature reach above 35C, Remotec support told me. any way, I am OK, just minor issue.
yes this is a firmware bug.
the ZXT broke shortly after i post this, Remotec send me a new one with 1.6 firmware … and now everything is correct … if iam out of home for 2 days … temperature can go up to 37 un the upper rooms … its now show correctly.
