ZXT-120 not learning
I have a ZXT-120 Version 1.4 (had a 1.0 before but had it replaced)and a Daikin AC. I have tried all the new built in codes with my Daikin AC. 2 of them sort of work. I can switch the AC on or off, but it only comes on in Fan mode low, i cannot set it to high via the Vera. So i tried learning, i managed to learn with the V1.0 which i had before, but i cannot remember how i have done it. I keep trying, but it does not learn.
This is what i am doing to get it to learn:
I have set parameter 27 to 000 (tried 2 byte dec and 4 byte dec), press save, that works, flashes twice which suggests its in learning mode. Now i go back into device options, (tried 1 byte dec and 2 byte dec), add parameter 25, desired value 1, press save, wait for the zxt to flash, point the remote at it, and it flashes 6 times. What am i doing wrong ? Is there another way to get it to learn codes ?
did you follow these instructions: http://forum.micasaverde.com/index.php/topic,11660.msg112037.html#msg112037
yes i did, but for whatever reason i never get a success, just the 6 flashes meaning it has not learned the code
