ZXT-120 as a IR gateway
Hi everyone,
I bought a ZXT-120 from Remotec. The device is listed as a IR extender for AC unit. It has a temp sensor and work both in FLiRS or Always on (Usb power adaptor). So basically, the device can record 22 IR codes that are all associated with a specific temperature. so let say I trigger the device from Vera to go at 22?C cool, the device will emit a specific IR code it was trained for.
That part works perfectly for me. The thing is, I don’t use it to control my AC but my electric curtains and TV :slight_smile: !
I was able to program specific temps to do specific IR code (ie : 19?C cool = open curtains ; 20?C cool = close curtains, etc…)
But now I would need some help to change the layout of the device in the Vera UI7 interface to make it look way more like a remote (let say with 22 momentary switches). Right know, after detection, it showed up as a hvac thermostat witch make sense since that was the main function :slight_smile:
Could anybody help me with that ? I saw the xml and json files both for a binary switch and the hvac but I can’t figure it !
Thanks for your help :slight_smile:
binary switch xml:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:BinaryLight:1 D_BinaryLight1.json urn:schemas-upnp-org:service:SwitchPower:1 urn:upnp-org:serviceId:SwitchPower1 S_SwitchPower1.xml urn:schemas-micasaverde-com:service:EnergyMetering:1 urn:micasaverde-com:serviceId:EnergyMetering1 S_EnergyMetering1.xml urn:schemas-micasaverde-com:service:HaDevice:1 urn:micasaverde-com:serviceId:HaDevice1 S_HaDevice1.xml
HVACzoneThermostat1 xml
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:HVAC_ZoneThermostat:1 D_HVAC_ZoneThermostat1.json urn:schemas-upnp-org:service:HVAC_FanOperatingMode:1 urn:upnp-org:serviceId:HVAC_FanOperatingMode1 S_HVAC_FanOperatingMode1.xml urn:micasaverde-com:serviceId:HVAC_OperatingState:1 urn:micasaverde-com:serviceId:HVAC_OperatingState1 S_HVAC_OperatingState1.xml urn:schemas-upnp-org:service:HVAC_UserOperatingMode:1 urn:upnp-org:serviceId:HVAC_UserOperatingMode1 S_HVAC_UserOperatingMode1.xml urn:schemas-upnp-org:service:FanSpeed:1 urn:upnp-org:serviceId:FanSpeed1 S_FanSpeed1.xml urn:schemas-upnp-org:service:TemperatureSensor:1 urn:upnp-org:serviceId:TemperatureSensor1 S_TemperatureSensor1.xml urn:schemas-upnp-org:service:TemperatureSetpoint:1 urn:upnp-org:serviceId:TemperatureSetpoint1 S_TemperatureSetpoint1.xml urn:schemas-upnp-org:service:TemperatureSetpoint:1 urn:upnp-org:serviceId:TemperatureSetpoint1_Heat S_TemperatureSetpoint1.xml urn:schemas-upnp-org:service:TemperatureSetpoint:1 urn:upnp-org:serviceId:TemperatureSetpoint1_Cool S_TemperatureSetpoint1.xml urn:schemas-upnp-org:service:SwitchPower:1 urn:upnp-org:serviceId:SwitchPower1 S_SwitchPower1.xml urn:schemas-micasaverde-com:service:EnergyMetering:1 urn:micasaverde-com:serviceId:EnergyMetering1 S_EnergyMetering1.xml urn:schemas-micasaverde-com:service:HaDevice:1 urn:micasaverde-com:serviceId:HaDevice1 S_HaDevice1.xml
