Zwave/Zigbee/Bluetooth not staying active
New problem here on a VeraPlus. It seems that just tonight the Zwave/Zigbee/Bluetooth LEDs on the unit will cycle on and then off in a continuous loop. Switches/Dimmers that I try to activate suddenly turn up as ‘cannot connect to device’. I have tried the memory clearing commands and so far it hasn’t solved the problem. Memory hasn’t been an issue yet for me, tracked using datayours. Anyone else experience this?
EDIT: Also the panel manager reads, “failure” for status…
EDIT: updated firmware to latest version. now the panel manager reads, “This device does not appear to offer Z-Wave communications.” —ummm…okay.
EDIT: And now it seems to be working again. Panel manager reads, “OK”, and cycling devices seems to re-sync them after they previously could not be detected. Was it just me or did others experience this issue. BTW, I did check the memory used and it never fell below 75kB.
