Zwave Routing Matrix blank after upgrade to 3.20 (RESOLVED)
I’ve upgraded to 3.20 using the hack to convert from 2.78 and my Zwave routing matrix as reported by ADD is empty. I’ve tried HEAL several times using the following parameters:
CHECKED:
By default MiOS should automatically configure devices
Use Z-Wave version 3.20 instead of 2.78 IMPORTANT: Read this first
Use MiOS routing instead of Z-Wave (requires 4.5)
Poll nodes learn more
Only update MiOS routing (overrides other settings)
NOT_CHECKED
Limit neighbors to Z-Wave discovery (requries MiOS routing)
Re-configure all the devices when done.
Is there a set of settings for HEAL that will work? I’ve read all the messages several times regarding HEAL and frankly, the information seems conflicting and contradictory regarding how to actually perform a HEAL with version 3.20. Please post your HEAL settings that work for you. Thanks!
After running HEAL with every possible configuration I finally manged to get my ZWave routing to work. For those that are interested, here are my settings:
ON the OPTIONS TAB:
CHECKED:
NOT_CHECKED
THEN on the REPAIR TAB, UNCHECK both
Click “GO” and wait for completion. IN my case this took about 3 hours with 25 devices.
