I have setup a security system with a Vera lite and a few pir and door sensors. I installed everything on the kitchentable and it worked marvelous.
Now I have installed it in the field. The problem is that some of the sensors and switches can’t be reached anymore. I have had this before at my home, but after a lot of trial and error, I managed to get it working.
The point here is that I had to extend the wifi range to a barn. So I used a enh500 from engenius to do so. From the router, it goes to the first antenna that will send it to the next antenna 200 meters further. There I connect another AP (Engenius 300).
Now the point is that all the sensors that are in direct contact with the main router are working fine. However, all the sensors at the other end of the wifi antenna can’t be reached anymore.
Is anybody familiar with this problem? Is it possible to update the routing or is thi a more severe problem.
I have read all the zwave routing posts etc, but can’t seen to find a solution to this problem.
You will always have issues if you configure your devices and then relocate them. Often, given time and a few network heals, the Z-Wave network will figure it all out, but sometimes it is not possible for the Z-Wave network and Vera to figure out the needed routing after a relocation. It is always best to include and configure Z-Wave devices in their final operating location.
To clarify my understanding: Are you saying that you have Z-Wave nodes at the opposite ends of a WiFi bridge with a Vera at one end and the switch at the other?
If this is what you are saying, the remote nodes will never work. Z-Wave uses its own frequency and routing. A Z-Wave network, used to communicate between Z-Wave nodes within 5-10m of each other is discreet from WiFi and cannot run across your WiFi bridge.
Your only hope in such a scenario would be to use two or more Vera, one Vera on each end of the WiFi bridge, controlling local Z-Wave nodes. See Vera bridging.
Switch <> Outlet <> Vera <====WiFi Bridge===============WiFi Bridge===> Vera <~~> Switch
I expected the zwave to get over the bridge. But in this case I see it is not possible. The explanation you refer at is rather short. Can you explain me a few things?
Can I include the sensors etc. in the second vera and than just leave all the logic in the first vera?
Can I just copy the whole logic into the new vera?
What if I want to trigger an event at the second vera (running a scene) but the logic is in the first vera. And I am in range of the second vera and not in range of the first vera?
Is it possible to combine the two Vera’s to be seen as one from any side of the wifi and from a mobile device over the internet?
I know it is a lot of questions, but this is new for me.
I'm not sure what you are asking here. It is possible to restore another Vera's configuration from backup, however, the two could not operate at the same time as they would be clones including Vera IDs. If you mean that you want to copy scenes from one to another, I don't think this is possible.
This can be done easily. Whoever, if you are running all your logic on one Vera, the scenes would all be there, no?
Bridged Vera's communicate with each other via TCP/IP. If you can communicate via TCP/IP with the second Vera, you should also be able to do so with the first.
Is it possible to combine the two Vera's to be seen as one from any side of the wifi and from a mobile device over the internet?
Yes. Mostly.
[url=http://docs5.mios.com/doc.php?language=1&manual=1&platform=3Lite&page=multiple_units]The manual[/url] may help your understanding. There are also a few threads on this forum that discuss using bridge Vera's.
http://forum.micasaverde.com/index.php?topic=13585.0.html
http://forum.micasaverde.com/index.php/topic,13521.0.html
Because I need wifi in the rest of the barn I like to add an AP that is a little stronger. Can I use it like this; a normal switch with the Vera and the AP connected and then connect the switch to the Wifi bridge? The part at the internet router is already working.
You can do something like that. But, there may be a catch. Your diagram suggests that you want one Vera on the internal LAN side of your router and the other Vera on the external internet side of the router. This won’t work safely without VPN tunneling.
But, if you meant to have both Veras on the internal LAN side of the router, it will work fine so long as your WiFi bridge is reliable. The diagram would look like this:
Vera<==>Switch<==>AP
^======WIFI Bridge===========WIFI Bridge==========>Internet router <==> Internet
Vera <=====^
OK, I am confused. I set up the second vera as mentioned above. I can see it over every wifi spot, whether it is in the house or in the barn. I can ping it from anywhere.
Now I try to bridge it to the first vera. I see all the other UPnP devices except the vera.
The configuration is as mentioned before. Vera 1 is on the internet (modem) router which is also connected at the wifi antenna. From there it goes to the other antenna and from there to a switch. On this switch I have the vera2 and an engenius ecb300
Any idea why it can’t see the second vera, or which steps I could take to troubleshoot?
If you can ping both Veras, then presumably the Veras should be able to reach each other. This suggests that networking is correct.
Are the Veras on the same IP subnet? I’m pretty sure that the UPnP discovery does not work across subnets. It may be possible to enter an address manually, but I don’t know how.
Did you scan, Save, and wait 10 minutes, as described in the instructions?
Somebody mentioned that they can’ be on seperate DHCP servers. I have to check that tomorrow. The strange thing is that I can see all the wifi bridges and AP’s in between as UPnP device except the vera. I have to check if it will work with a static IP.
At this moment they both have internet access, so I assume that both vera’s are on the same DHCP server as well. But UPnP runs over UDP, so maybe there is the failure???
You are not providing critical information about your network, specifically the bridging and addressing, and I can only assume that you know what you are doing.
Are both Veras on the same subnet? What is the IP of Vera1 and Vera 2?
Are the Engenius bridges configured to bridge or to route? WDS or Client Bridge mode?
Does the Engenius have broadcast or multicast filtering capability/enabled?
No I am a network illiterate. The first vera is on
=== IP Configuration === eth0 Link encap:Ethernet HWaddr 00:0E:8F:C7:6C:D0 inet addr:192.168.81.1 Bcast:192.168.81.255 Mask:255.255.255.0 eth0:0 Link encap:Ethernet HWaddr 00:0E:8F:C7:6C:D0 inet addr:192.168.1.72 Bcast:192.168.1.255 Mask:255.255.255.0 inet addr:127.0.0.1 Mask:255.0.0.0
I am not there at the moment, but the other Vera, I think, is the other way around. So eth0 on 192.168.1.85 and the eth0:0 on 192.168.81.1, but I am not sure.
The bridge is an Engenius enh500. the first antenna (near the house) is setup as an AP. The second one at the barn is setup as client bridge. The AP is set to DHCP and the client bridge is set to a static IP in the range of 192.168.1.xxx
So there is a lot of stuff between it. But the first Vera sees the following UPnP devices:
Add control over another UPnP device, such as another Vera.
Click add for the device you want to control. Then wait a few minutes for Vera to scan the device, after which time it will appear as a new device. If you have any unsaved changes, meaning the save button in the upper right is red, save your changes before adding the device.
VGV7519 WFA-WCN Device (Modem internet)
WANConnectionDevice ??
WANDevice ??
LANDevice ??
TR064 ??
DSL Router(WAN Con) Probably the wifi antenna’s
DSL Router(WAN) Probably the wifi antenna’s
This means they are on the same subnet. This should work.
My only other thought is that the UPnP discovery multicast is being filtered by the Engenius WiFi bridge, a process sometimes called IGMP snooping. However a Google search provides me no clues about Engenius and multicast/IGMP snooping capability or configuration. You might ask Engenius support.
Assuming my filtering theory is correct, it will be necessary to disable IGMP snooping. Alternatively the Vera MiOS engine bridge will need to be manually configured. I don’t know how to do this, or if it can be done. You may need Micasaverde support for this.
