zWave Network Quality/Routes not all appearing
Hello amg0,
Chrome 44.0.2403.155
Vera3 UI7 1.7.649
Console log extract - many lines pic attached
When viewing Network Routes or Quality I only see one device. There should be a Secure ST321 thermostat and several TKB TZ68E switches appearing. Have read other posts about this but am unable to perform a repair network (think this has been removed from UI7).
Also have recently upgraded from UI5 to 7.
Any help much appreciated.
PS Hope I did the right thing by starting a new thread!?
[quote=“powisquare, post:1, topic:188416”]Hello amg0,
Vera3 UI7 1.7.649
PS Hope I did the right thing by starting a new thread!?[/quote]
yes you did the right thing.
ALTUI version ?
you d need to try again and have the complete javascript console log from the start to the latest message. you can copy/paste the text to get it all.
AltUI v0.65.622, amg0,30107174
Hope this helps …
Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user’s experience. For more help, check http://xhr.spec.whatwg.org/.
Failed to load resourcerapport_nikko_on_blur @ VM367:49
Failed to load resourcerapport_nikko_send_focus_event @ VM367:62
2Failed to load resourcerapport_nikko_send_focus_event @ VM367:62
2Failed to load resourcerapport_nikko_on_blur @ VM367:49
3Failed to load resourcerapport_nikko_send_focus_event @ VM367:62
3Failed to load resourcerapport_nikko_on_blur @ VM367:49
http://192.168.1.170/cmh/skins/default/icons/intro.png Failed to load resource: the server responded with a status of 404 (Not Found)
4Failed to load resourcerapport_nikko_on_blur @ VM367:49
4Failed to load resourcerapport_nikko_send_focus_event @ VM367:62
5Failed to load resourcerapport_nikko_send_focus_event @ VM367:62
5Failed to load resourcerapport_nikko_on_blur @ VM367:49
6Failed to load resourcerapport_nikko_send_focus_event @ VM367:62
6Failed to load resourcerapport_nikko_on_blur @ VM367:49
no that does not really help as these error are not comign from ALTUI, most likely them come from UI5 or UI7
try to close ALL windows and open just ALTUI main page. then open javascript console CTRL+SHIFT+J on chrome , then click on the little ‘no parking’ sign on the top left corner of the console
then go to ALTUI main window, force a refresh, then go into the zwave quality page to observe your issue
then go to console and copy paste the content
thx
Ok thx - this comes up …
GET http://nikkomsgchannel/e?00160023005b00210033004000690052005a0050005c005400?28005a005a005d00140057005d004100540078005a002b002d00580059005f005b005d005e rapport_nikko_send_focus_event @ VM126:62rapport_nikko_on_focus @ VM126:72
VM126:49 GET http://nikkomsgchannel/e?00160023005b00210033004000690052005a0050005c005400?5d005f005d005e00170054005c004b00280009002c002f0058005d005e005c0058005e005f rapport_nikko_on_blur @ VM126:49
VM126:62 GET http://nikkomsgchannel/e?00160023005b00210033004000690052005a0050005c005400?28005a005a005d00140057005d004100540078005a002b002d00580059005f005b005d005e rapport_nikko_send_focus_event @ VM126:62rapport_nikko_on_focus @ VM126:72
[quote=“powisquare, post:5, topic:188416”]Ok thx - this comes up …
VM126:49 GET http://nikkomsgchannel/e?00160023005b00210033004000690052005a0050005c005400?5d005f005d005e00170054005c004b00280009002c002f0058005d005e005c0058005e005f rapport_nikko_on_blur @ VM126:49[/quote]
umm neither… this http://nikkomsgchannel has nothing to do with altui.
do you use this “rapport software” mentioned here ? : Using Jquery submit with ajax request - WordPress Development Stack Exchange
I do not think this is the cause of our issues here with ALTUI.
Yes indeed - trust I have not revealed anything of consequence! So … tried it on a clean(er) machine and no logs appear at all now!? Hope this is good news …
no you have not revealed anything.
However I still do not know what happens to your altui
so:
a) do you have zwave devices
b) can you go into MISC DEBUG Variable Search and type codeRoute [/code]and execute and give the result back ?
Thx for your patience amg0 - here we go …
“device”: “0-15”,
“name”: “Boiler Relay OF”,
“state”: {
“service”: “urn:micasaverde-com:serviceId:ZWaveDevice1”,
“variable”: “AutoRoute”,
“value”: “0-5x”,
“id”: 18
[quote=“powisquare, post:9, topic:188416”]Thx for your patience amg0 - here we go …
“device”: “0-15”,
“state”: {
“value”: “0-5x”,
“id”: 18
][/quote]
that is all you get ? you have only one device with either ManualRoute or AutoRoute variable and this one does not even have a valid route ( it finished with an x which means invalid )…
I am afraid the route quality diagram cannot draw anything as it relies on these AutoRoute or ManualRoute variables. but that is really strange…
to be sure, you may check the output of the MISC / DEBUG / All Devices to verify what devices have a route information or not
thx
Will do. Is there a url for remote access login? Otherwise I shall be back on Friday …
for UI7 => https://vera-ui.strongcubedfitness.com/Veralogin.php
for UI5 => read “readmefirst” http://forum.micasaverde.com/index.php/topic,33309.0.html
Not sure what to look for and it’s quite long so have attached it …
I got the info but deleted the file for confidentiality reasons. I ll look at it
ok so I looked at it and indeed I see no indication of manual or auto route. maybe that is the new way the latest UI7 firmware is dealing with route but I have no documentation on that, so for now, cannot do much about it. the graph is not functional in that case. will come back on it if I find some documentation on this new route management of the latest UI7. thx
OK thanks amg0.
If you have UI7.09 you can run the: Z-Wave Settings, Repair function with checking the “Only update Vera routing (overrides other settings)” option. That populated the autoroute variable for all my devices on UI7.
Not sure this still exists on 7.10 as I am not brave enough to install that yet ;D
Cheers Rene
Thank you Rene - will investigate.
Downgraded to v. 7.09 which is firmware 1.7.619 (why don’t they keep things simple?!) and followed reneboer’s advice. Works! Thanks both - the .10 firmware release has a big change relating to the z-wave chip and as someone else pointed out it should be viewed as a .0 release!
:slight_smile: happy you have a way forward, however if anybody finds out how .10 firmware routing works and is memorized inside the user_data, please let me know so I can adjust
