I have been searching the forums, but can’t seem to find whether there is a battery-operated z wave motor that can control a daisy chain on a window shade.
I understand there are tubular motors, but wondered if this could be a simple add-on.
I saw something that you could add on that would tilt slat blinds (not Z-Wave) and there is always the Drapery Add-A-Motor but that might require you change the chain out for a cord (shade clutch should work with either chain or the correct diameter cord).
Otherwise you are better off looking into tubular motors or creating something yourself.
