I’m going into device options and adding a configuration setting with a variable of 7. If I leave the data size as default, it takes the configuration but there is no change. If I change the data size to anything else, the config fails.
Did you try clicking Configure node right now on the Settings tab and immediately waking up the device (single click on the tamper switch)? It sometimes takes a few attempts.
Same problem with other parameters.
I’m starting to suspect that it’s got connectivity issues. I left it doing a heal earlier with parameter 7 set to 100, and it evidently took as the temperature went up significantly. However, I still saw a User Configuration error on the device.
I’ve got a couple more wired devices arriving in the next few days which will help with the network. I’ll give it another go then.
