I have assembled a zwave based security system using a Vera Lite and a Keypad from China (AC-301, but it also goes by several other model numbers). I used door sensor external contacts to communicate “Alarm off” and another sensor for a “tamper” condition. Now to my question. I need a small zwave controlled LED indicator light to indicate an armed condition. Does this item exist? I would prefer to not use a large 120v indicator light with an appliance controller. Thanks for anyone’s help…
Maybe the HSM200 also sold as EXMultiPli ?
It plugs directly into an outlet and has 7 programmable colors plus off.
You have to install the EZM Light Utility App to actually be able to control the colors.
I use Pink on my to indicate if the alarm is set and Yellow to indicate an alarm occurred. When the alarm isn’t set I use Blue, Red, and White based on the temperature sensor that is included (it is also a motion sensor and light sensor).
Thanks for the recommendation, but this indicator light will be beside the keypad in a small outdoor wall box with a waterproof door on it. I also don’t want 120v in this box. I am afraid that at this point in time that there is not a zwave controlled small indicator light available. Any other suggestions? Thanks…
Use the Fibaro RGBW LED controller module. That gets its power from 120V, but then you can run a pair of low voltage 12v wires out to the box and put an LED on the end of that, or a small LED strip. The HSM200/EZMultiPli or the Fibaro are really the only solutions I can think of
