I need understand if the zwave device has a memory to record configuration or if only sends signal.
I wanna take off a device what is installed in a vera3 controller and install in another network with another vera3 controller and I need know if I have to reset the device before this changing.
Piwtorak, some Z-wave devices have a small number of persistent settings that they retain in nonvolatile memory. You can see them in Device Options > Configuration Settings on a device’s dialog.
If you exclude a device from one Z-Wave network and add it to another, those configuration settings might reset, or they might remain. It really depends on the device.
The devices can only be included into one primary controller’s Z-Wave network. If you have multiple controllers, then you included those into the primary controller’s Z-Wave network as well, and they all became secondary controllers.
Because all devices were included (‘paired’) with the primary controller, they are able to talk to each other.
