Zwave Consulting
Hello guys
I am having a new project which is a villa 2 floors (500 m2 each) square shape
It is my first project in such a big area, i want to build a full smart system on Vera (multi veras ofcourse)
I want like a company which help me I can consult it.
Do you recommend any?
You can get a lot of free recommendations here :slight_smile: … sometimes you get what you pay for :(.
If you want suggestions on a consultant you might need to indicate where you are located … Since your sizes are meters … I assume it’s NOT the US.
That’s pretty big size … Design will be influenced by the kind of construction that will limit Z-Wave communications (i.e. Wall Construction material between rooms, Number Of rooms, Construction material between upper and lower floors)
