I’m trying to pair these with no success. Since there are not in the existing roster, I’m trying to add them as a generic ZWave device. No success. Any ideas what I should try?
In the micasaverde catalog is at position, 672 WENZHOU MTLC ELECTRIC APPLIANCES CO.,LTD. ZW15S ENERWAVE Z-WAVE On/Off Switch United States Lighting, On/Off Switch
Anyone succeeded to pair these with a VeraPlus?
I have the ZW15SM (energy metering) and added as a generic Z-Wave device with no issues on Vera Plus running UI7. I’ve had this switch for 1.5 years and it’s been rock-solid.
What Vera model/firmware version do you have?
I have VeraPlus. How did you add it? I tried the Generic ZWave and nothing happened…
I dont know how to put the switch in Pairing mode. The instruction sheet does not say… grrrr
Odd. The instruction sheet I received is quite good. In any case, here’s a link to the instruction sheet:
http://enerwaveautomation.com/wp-content/uploads/products/zw15s/ZW15S-N-0207160026-01-1.pdf
See if this helps—note they suggest performing an exclusion prior to including the device.
