Is it possible to associate a scene with group 3. The manual says if you tap the button 3 times it will activate group 3 devices.
Basically i would like to configure the switch by the back door when pushed 3 times to set door sensor on bypass for 10 minutes.
Does that make sense or do i need to install a scene controller?
