The smartest house has these on sale for $25.50 in their labor day sale. They claim to be able to use traditional add-on switches in 3 and 4 way configurations.
Anyone have any experience with them?
I just installed a couple, one of each type in a 3 way setting. The dimmer still has the long fade out effect I dislike (and I haven’t find a way to reduce it), but they both work great.
I had a little trouble with the faceplates they are a hair bit bigger than the regular paddle switches. I had to file 1mm from the bottom of the hole so I don’t have to push it too hard. Also on the dimmer, the extra switch only has on/off capabilities as expected, so it will only turn off and on (to the latest level)
I just installed 2 of these, one in a single switch application and one in a 3-way.
The 3-way was working correctly when installed(I could turn on/off from the zwave switch or the dumb switch) I turned breaker off, put all back together, now it is acting weird, I have to have the dumb switch in a certain position for the zwave switch to work.
Also they are quite wide and stick out a little bit more, I put 2 of these in a 4 gang box and could not have them side-by-side like the switches they were replacing. Also for pairing, the instructions that came in the boxes, said to toggle 3 times(on-off-on), that is incorrect, you have to toggle on 3 times. Their website has the correct pairing instructions.
I haven’t shaved anything of them yet, so the wall plate does not sit flush against the wall, but that is on the to-do list.
Just started installing them and I went straight to. 4 way set up. It works fine with one slave switch but not the other. I am wondering if they are Daisy chained together,as there is only one traveler on the master.
I found it works ok with regular 3 way switches but is not happy if the lights are in wired in between the switches,as compared to on the end. Most of my lighting is set up as power-switch-light-switch-switch so they aren’t as useful for me as I hoped.
If you have trouble getting them to pair, set the switch off and click up 3 times during pairing. As in on-on-on, not on-off-on-off-on.
