Zmodo Mini IP Camera Baby Monitor Two Way Audio Night Vision? (ZH-IXB1D-WAC)
Does anybody know if this IP camera should work on Vera Edge UI7?
As far as I can see, the model is: ZH-IXB1D-WAC
Is there a list of cams which are working on the Vera Edge UI7, running latest firmware?
edit: found it: http://wiki.micasaverde.com/index.php/IP_Cameras
But no Zmodo in the list.
