I have 16 Cameras on my DVR from ZMODO. The DVR has only 1 IP Address with 16 channels. I install the DVR Plug Ins, but i can not make it work.
I added the IP (Valid one), the DVR command Port (5050) and username and password. I have Vera 3 as primary controller, when i configure the DVR Plugin, it creates just 1 camera, but it does not work. Any initial Tip ?
I believe this has been discussed prior and you may want to use the search function. But I do not believe that the zmodo will work. If the unit has a direct image url for the cameras, you will need to use that and manually setup the camera device. Instructions can be found on the forum on how to create manually create a camera device. I would not use the DVR plugin as I have not heard anyone having success with it. It’s functionally it very basic at that and does not do what many have hoped it does.
- Garrett
