[quote=“EricwithVera, post:41, topic:182328”]I have the latest firmware of UI7 with the Vera Edge, 1.7.1248.
I added the tag reader (is same as be-next I believe) as a generic device, Vera recognized it immediately as a keypad. Once it is recognized, have some patience (a general good advice for adding stuff), as soon as Vera has found the device, it will start adding functionality to it. It took a few minutes before all options became available.
Go to devices,
then select keypad,
select Pin codes,
click add badge. (You can also select “add pin code” btw)
The system will now tell you to give the “to be added” badge a name, push the home or away button and to put the new badge in front of it.
Immediately after this, the new badge nr will be added, and the system is updated.
Make sure you name your badge correctly from the start. You cannot modify it afterwards, except for deleting it and adding it again.
For me the setup is straight forward and done in a breeze.
Since the tags can be named, you know who is entering the house or leaving. You can ask the system to send an email for this etc.
Let me know if it works for you?
Eric[/quote]
Hi Eric,
Your response is highly appreciated, so based on your findings I’ve ordered the Zipato wt-rfid.eu keypad version.
The BeNext version looks similar but is apparently not the same version as the Zipato version, since it shows up as a door lock, and having it as a doorlock means certain functions can not be used like detecting home/away mode etc. And trust me I did hours, and hours of research on the BeNext model but without any success. I’ve tried contacting Vera support, after 2 days they came back with a answer not related to my question… I’ve asked if they could use the same device template on the BeNext model which they use for the Zipato version…
So for others reading this:
The BeNext keypad looks similar as the Zipato one, but once installed you will notice the following behaviour;
- Installed as a Key Lock
- Home/Away mode not usable in scenes, since the modes are not recognized by Vera
- Only on Tag can be added, and this will occupy position 1 of the 10 pincodes you can set.
- For this version it was needed to install the PlugIn TagReader
@Eric: One more question, did you also needed to install the Plugin TagReader for the Zipato version to program the various FOBS? I’ll let you know how it works with the Zipato version.
Regards,
Pierre
Using: VeraEdge UI7, Version 1.7.1248
